frocashmoney24 Posted July 2, 2005 Report Posted July 2, 2005 (edited) I have a 95 warrior roller, with newer plastics with ceet graphics, holeshots with itps in the back, almost new knarly's on the front, dg bumper, 400ex shocks, everythings there minus engine-related objects, and right brake caliper for the front. comes wtih gas tank and everything seen in picture, the plastics arent bolted down in the pictures, nor are the rims, thats why they look tipsy, not perfect, the frames been welded up due to hittin a tree, just needs to be straigned. make me a offer. Also have the motor, matching cases, bottom end all in tact, the top end is missing the piston, and cam chain which is all i know. i bought this whole quad from a friend who wanted to get rid of it, and intened on rebuilding, then college bills rolled in and its leavin me. could possibly be able to throw in a new piston and go with a hone. like i said i never cracked it open, but it appears to me as if everything was there, it ran before he took out the piston.motor comes with starter, cdi, coil, and everything else electrical. case was broke due to a hopped chain, but was fixed with jbweld and doesent leak, there are also broken bolts on the stator and clutch side, but you can get them all out, i just dont have time, again make a offer Ill let this stuff go cheap, would be a good project for someone, sell apart or whole. Located in 14873 Ny, would only like pickup, unless buyer arranges all shipping. Everything is sold AS IS. going on ebay sometime, thanks for your time! Edited July 2, 2005 by frocashmoney24 Quote
ellison445 Posted July 5, 2005 Report Posted July 5, 2005 (edited) Hey jeff, Those are bandit front tires Edited July 5, 2005 by ellison445 Quote
frocashmoney24 Posted July 5, 2005 Author Report Posted July 5, 2005 yes sir they are bandit fronts, 100 bucks, thanks but no thanks Quote
