one21 Posted June 28, 2005 Report Posted June 28, 2005 Does anyone know if Big Bore LRD Pipes will work on a stock banshee??..Or does it have to be bored? Quote
one21 Posted June 28, 2005 Author Report Posted June 28, 2005 Oh i forgot to mention that they are adjustable Quote
Ducman Posted June 28, 2005 Report Posted June 28, 2005 I'm sure they will work, that is, your bike will run and have top end power. However, those pipes aren't tuned for a stock motor, you may loose a fair amount of bottom end. It would be hard to say unless you tried them, but a pipe made for the stock motor would probably perform a lot better. The newer style LRD pipes (they do not make "adjustable" pipes anymore) are better. Quote
yamaha350 Posted June 29, 2005 Report Posted June 29, 2005 you will have to do more than bore your engine for these pipes to work to there full advantage. anyonw who bores out there cylinders is waisting the life of them. you will not gain any signifigant hp by doing this. you will need to add some stoke to it. probably need to get it around 420cc before these pipes will work. Quote
