FOXBANSHEE30 Posted June 24, 2005 Report Posted June 24, 2005 i have a stage II trinity 2 into 1 carb kit with a keihn PWK on it and i cant seem to get the needle out of the slide. Is there a certain way to get it out? Thanks. MEADOWS Quote
sredish Posted June 24, 2005 Report Posted June 24, 2005 Well, you have to put a 6mm ( I think) socket on the top of the slide and unscrew the needle top and then your needle should fall right out when turning over the slide. Look in the top of the slide and you'll see the little hex top to put the socket on. Quote
fixitrod Posted June 24, 2005 Report Posted June 24, 2005 It is a 6mm .. same as the main jets. Quote
pimpeinkc Posted June 25, 2005 Report Posted June 25, 2005 i always take out the cable, then i pull in the throutle and stick my finger in the intake side and hold the needle while i release the thumb and as the slde drops i grab hold top of the needle, and then i do a little dance. just because. good luck Quote
sredish Posted June 25, 2005 Report Posted June 25, 2005 i always take out the cable, then i pull in the throutle and stick my finger in the intake side and hold the needle while i release the thumb and as the slde drops i grab hold top of the needle, and then i do a little dance. just because. good luck 385586[/snapback] That's with your PJ tho, right? Do you do the dance in front of people? Quote
FOXBANSHEE30 Posted July 2, 2005 Author Report Posted July 2, 2005 thanks guys. i got the problem my needle was broke. MEADOWS Quote
