Live4Quadin Posted June 20, 2005 Report Posted June 20, 2005 Friend of mine has a new Banshee with Toomey T6's, K&N filter with the airbox vents that come with toomey's, and V-force 3 reeds. To my knowledge, these coolheads run cooler and bump up your compression? Also, which domes would be an all around dome for under 1500 feet i think (florida) and the gas that should be ran with it. We mainly run in the trails and pits. Thanx in advance for your help. Quote
applpro Posted June 20, 2005 Report Posted June 20, 2005 Friend of mine has a new Banshee with Toomey T6's, K&N filter with the airbox vents that come with toomey's, and V-force 3 reeds. To my knowledge, these coolheads run cooler and bump up your compression? Also, which domes would be an all around dome for under 1500 feet i think (florida) and the gas that should be ran with it. We mainly run in the trails and pits. Thanx in advance for your help. 383807[/snapback] You can select your dome size according to the octane that you want to run (and have access to). There are limits to the cylinder pressure that a stock crank can handle. Contact Noss Manufacturing for all the info & advice you will need. he sells a great product & provides super service. Quote
dlnoss Posted June 20, 2005 Report Posted June 20, 2005 The Noss heads run cooler than stock, most brands probably do. For sea level, 21cc domes will work with premium pump gas. If you want to run race or av gas, you could install smaller domes for even more performance. Quote
