So, I've had quite a few problems with my 03 shee. I changed all my top end gaskets recently and eliminated the TORS. Still, I have the one original problem. For some reason, the bike runs alright while at idle (minus the misfiring left cylinder), but the bigger problem I have is the overrevving when I'm not even touching the throttle. Its almost as if my slides are sticking, but they aren't because I'll leave it at idle and out of no where she slowly revs up to WOT. I shut it off, start it back up without touching my throttle and its back to normal. My carbs are fine, I had them looked at by someone who knows a lot more than me. I don't really know too much about Banshee's so all help and suggestions would be appreciated. What should I check?
Thanks dudes.
Thanks dudes.
383805[/snapback]
If I ever have problems with my shee I rule out air leaks.If I was you do a pressure test.I spent under $10 for the parts from a hardware store.I would start with that!
I know you've had your carbs looked at but do this. Take the air filter off and watch the slides. See if one started to go up when you get the revving action. You might be suprised :huh:
If that's not it try a buddies cdi. Maybe it's going wacky.
