i have a 1987 shee...as some of you may know i have been doing a lot of work to it lately..kinda like a restore project...overall the bike is in really great shape...the frame is straight..but i want to do something different with the front end as far as shocks go...will the yfz shocks work...like a direct bolt on with little to no modification....i am gonna get the sterring stab. from noss...just want some better shocks..thanks
they wont bolt direclty on but will work with some modification. you have to grind a little of the bottom of the shocks and I think grind the shock mounts a little. they are well worth it for a quick suspension fix, unless you want to go all out and get some works or elkas.
i really dont want to spend the money on the shocks from works or elka....they are a very nice shock just a little out of my pirce range right now....what other shocks work with the shee
i would like to see some pics of the modification if possible.....i want to do this...cause i have a feeling with the stoker kit in the engine i will want a bette suspension
the mod is very easy and yes in my case it made a noticeable difference with and with a little extra polishing you can shine and smooth the piggybacks up LOOKS GREAT!! B) if you need detailed inst. let me know and ill post it w/pics
Edited by champ6966
383892[/snapback]
I would love to see some detailed pictures. I'm getting ready to put mine on and it looks like it would require grinding a lot off the bottom of the shocks. I'm not sure I like that.
