macgillivary Posted June 16, 2005 Report Posted June 16, 2005 o man this sucks i put on new rear brakes but for some dumb reason i took the brake line off in the process anyways now the brakes are on the bike but when i press my brake pedal they dont work, the pedal goes down but no pressure on the pads there is still fluid in the lines, maybe not enough? when the line was off and you pressed the pedal you could see the fluid come out air in the lines causing problems? how do you get the air out? orrrrr what is the problem? Thanks Quote
DMAN94 Posted June 16, 2005 Report Posted June 16, 2005 bleed the line. you'll be fune. do it till you have pressure. tighten screw, press pedal several times, hold down pedal and open screw. Quote
macgillivary Posted June 20, 2005 Author Report Posted June 20, 2005 (edited) tryed doing this for so long and still nothing now what i noticed is that when you take the line off and press the pedal no fluid is coming out which was not like before, before fluid was coming out, even though there is fluid there, i put it in but it doenst seem to travel to the other end any suggestions on this? Thanks Edited June 21, 2005 by macgillivary Quote
