i heard you should purge a motor after running methanol through it. i am running a 28 to 1 ratio klotz super techniplate mix. will the cylinders rust if i dont protect them or is the oil enough? anyone have this problem? thanks.
One of the local guys that helps me out with my banshee runs methanol in his and after everyride he runs a little bit of 110 through it. I know this cause everytime I go over to have him help me with the shee he steals some of my gas <_<
I use alcohol in my banshee.I mix the oil 40 to 1.You need to purge it the end of every day that you ride.I purge with 93 octane mixed with the same type of oil I use(Benoil).The easiest way I've found to purge the quad was to take a small funnel,put a hose over the end of the funnel.Hook it to the T in the fuel line.Run it for about 3 minutes.I also drain the gas tank at the end of the day too.I don't know if it's the oil breaking down or what,but if I have left over gas mixed with oil that has sit for awhile,I'll find stuff floating in the alcohol.Alot of stuff.
379984[/snapback]
thanks for the reply and i will definitely follow your instructions
380106[/snapback]
PM me if you have any more questions.I'm new to the alcohol too,but trying to learn as fast as I can.Might can save you some trouble.Not a pro tuner by any means though,but will try to help.
