Ok i have a tz 750 barrel just one so it has 2 pistions in a single block. it has a hell of alot more cooling cap. than the stock. plus it is bigger. it is a 375cc to start and im still going to bore it. it has a rd cl bottom end with it. It should be interesting to see how many of my aftermarket parts will actually fit on to it. but if any one else has done this and can tell me what to expect to run in to that would be great. thanks
Will it bolt on to a RD bottom end?
I would think that the hole patterns for the studs and the centerlines of the cylinders would be different.
Are you putting this in a Banshee?
750cc 2 stroke Banshee, that would be cool............ :whoa:
