Bansheeslut03 Posted May 30, 2005 Report Posted May 30, 2005 I live in watertown ny and just got some K&N filters (i have no airbox now) and fmf gnarly pipes so i need to know what i should rejet my crabs too. right now the plugs are dark and it seems like there is no bottom end. Quote
Banshee~ Posted May 30, 2005 Report Posted May 30, 2005 around 340 mains, 27.5 pilots on stock carbs....do a plug chop to be sure. Quote
race-a-holic Posted May 30, 2005 Report Posted May 30, 2005 I live in watertown ny and just got some K&N filters (i have no airbox now) and fmf gnarly pipes so i need to know what i should rejet my crabs too. right now the plugs are dark and it seems like there is no bottom end. 375275[/snapback] You should need at least a 340 main jet.You also won't have much bottom end on a piped banshee.Mid to top end should be improved.It should run away from a stock banshee.Getting rid of the airbox is a good idea as long as you don't ride through alot of water or mud. Quote
fastbanshee4u Posted May 31, 2005 Report Posted May 31, 2005 I would say 30 pilots, needle clips moved down a notch. when you get it dialed in it will run great.better than stock in all ways.Just play with until you get it just right.pilots and air screws for low end,needles for mid range and mains for top end .What size mains do you have in now? Quote
