Guest nightmare
My wife's blaster was leaking oil really bad, so I changed the gasket on the clutch cover. My problem know is the kickstart will not move at all. Please help. I feel pretty stupid should have been a simple job. banghead
Tip it up on the side & pull the cover off, the kickstarter gears are most likely bound up. Shouldn't be a very tedious task to get it in there correctly, just make sure before you tighten the cover all the way back up that the kicker is grabbing correctly.
Guest nightmare
Thanks for the help Led. The problem ended up being( I hate to admit it ) I forgot to hook the spring back and it was binding everything up. I always do something stupid when I get in a hurry. :shootself:
