robinson373 Posted April 13, 2005 Report Posted April 13, 2005 I just did a compression check on my shee. 120 psi on shift side and 90 psi on kicker side. What would cause this. Just heard a new ticking noise in engine, did a ring break. Should my compression be more than 120 on the shifter side. I am at 420ft elevation. Quote
kenr74 Posted April 13, 2005 Report Posted April 13, 2005 They should be within 10% of each other or it is time for a rebuild. 90psi is really low. Did you check it a few times? Quote
sredish Posted April 13, 2005 Report Posted April 13, 2005 I just did a compression check on my shee. 120 psi on shift side and 90 psi on kicker side. What would cause this. Just heard a new ticking noise in engine, did a ring break. Should my compression be more than 120 on the shifter side. I am at 420ft elevation. 354698[/snapback] They shouldn't be any more than 5 psi apart, and neither should be below 95. You need to put new pistons in there. May or may not have to bore, dunno, a machinist will tell you, but you'll have to hone em anyway. You keep going with a difference like that and you'll be buying a new crank and possibly a cylinder if you screw up the one side. Buy a top end kit and put pistons in that beeotch. And get em ported while they''re off. Scott Quote
robinson373 Posted April 13, 2005 Author Report Posted April 13, 2005 I was told by a builder in the area that if he were to port my cylinders, I would have to buy a new aftermarket head to bring the compression back up. Is there any truth in this? Quote
racer Posted April 14, 2005 Report Posted April 14, 2005 I was told by a builder in the area that if he were to port my cylinders, I would have to buy a new aftermarket head to bring the compression back up. Is there any truth in this? 354782[/snapback] umm a little bit. porting can lower your comp due to the raised rooves. but i think a sotck milled head would do fine. Quote
sredish Posted April 14, 2005 Report Posted April 14, 2005 umm a little bit. porting can lower your comp due to the raised rooves. but i think a sotck milled head would do fine. 354968[/snapback] Word. and the machinist that bores/hones your cylinders can do your head for maybe $35. Quote
racer Posted April 14, 2005 Report Posted April 14, 2005 Word. and the machinist that bores/hones your cylinders can do your head for maybe $35. 355069[/snapback] they can be had on ebay for $10. Quote
