i bought my shee used, its a 97 and i dont kno what mm the carbs are, all that i know is there mukuni flat side or flat body , i think its the same but i want to rejet it. i live around 1000 feet above sea level, i mostly ride sandpits and soem trails, and the weather right now is nice, a little rainy though. what size do you recomend for pilot jet and main jet. cuz i dont kno reele anythin about jettin a carb, i read other posts but i want to kno like the sizes u guys recomend?
354346[/snapback]
On the right side of the carb right in the middle of the carb about half way up it, it'll have something like T28, T032, or T34 etc....That will tell you if it's a 28mm or 34 etc.....Then post and let us know what size carbs you got then go from there...
Yeah, you need to know what size carbs you have, (probably TM 28, 30, or 34) what size jets are in the carbs now, and most importantly how does it run now, i.e. really boggy off idle, part throttle, or WOT? Do you know if it has been ported?
I have the TM34's so I may be able to help some.
