is it a big deal that one of the coils on my stator is bent and rubbing the inside of my flywheel. still runs fine, i just don't want anything bad to happen
354183[/snapback]
My timing plate came loose and the stator and plate rubbed the flywheel for a little while. I tightened the plate and it runs fine. I can see where the stator had rubbed.
In your case,I would try to do something to keep the coil from continuing to rub the flywheel, though. Worse case scenario would probably just be continued stator damage, and you'd have to buy a new one.
