Giver 'er time...I'm sure somebody else will chime in. Before I had put in the V-force's I was around a 170 main w/ the needle on the first or second clip from the blunt end. It's gonna be hard to try to guess where you're needle clip is suppose to be. I think that's something you'll have to mess with when you get the main and pilot set.
By the way....how far away is Enfield, IL from eastern Iowa?
I would start with a 180 main and 52 pilot, needle 3rd clip
mine ran like a beast with that set-up, I moved to Reno (4500' above sea-level) and it ran perfect with a 170 main and the same set-up, plug chop was dead-on
**this was with a 38mm PWK though**
