im currently using golden Spectro and its petrolium based, i have a gallon of klotz super tech 2 and i was wondering would it be ok if i waste all the gas i currenlty have with golden in it and then use klotz? klotz does not mix with petrolium blend
So long as you drain out all the petrolium based oil then use the fuel with synthetic, you'll have no problems. But if you mix the two together, you could gum up your carbs and have a hell of a time cleanin everything out.
