82ndracer Posted March 24, 2005 Report Share Posted March 24, 2005 whats up everyone? bought my first banshee recently and have had nothing but bad luck. the shee has pro circuit pipes and silencers, vitos pistons at .30 over, v-force reeds and valve setup, pro-design intake. thing is fast as shit, when it runs. i took it to the shop to have inspected and the guy put 280 jets in it? is this too small? it has no low end until it gets into the mid and then screams. it bogs down at the first push of the throttle? i am worried it is getting to hot? i am no mechanic. any tips and info would be great as i am wanting to learn to work on this shit instead of paying the man! thanks by the way i am living in north carolina. Quote Link to comment Share on other sites More sharing options...
kw04 Posted March 24, 2005 Report Share Posted March 24, 2005 where you at man. i mean you at ft. bragg just asking cause of the name? Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 24, 2005 Report Share Posted March 24, 2005 Just got done sorting similar out on mine. 280 sounds about right...but, what are the pilot jets set at? Stock might not be flowing enough...which are 25. I'd bet you ned 27.5 Pilots, and then adjust the air screws somewhere between 1.0 to 2.5 turns out...all depends. Needle in 3rd clip? Stock carbs...K&N Pod filters/Boyseen Reeds and T5's on mine. I have 290s now...but, it also 35 to 40 right now...(actually colder at this second...and snowing..> Try the old choke trick. When it's warmed up...pull the choke 1/2 way out, first click. Run better? Pilots/air screw too lean. Bog down...Pilots/Air Screw too rich. I feel your pain. I just went through the same thing. I've almost got the bottom end cleaned up...very very close. I think my air screws are at about 1.5 to 2.0 out right now... Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 24, 2005 Report Share Posted March 24, 2005 Oh...and this article is a great "starting point" for it all... http://www.dfn.com/benkaren/jetfaq.html Quote Link to comment Share on other sites More sharing options...
82ndracer Posted March 24, 2005 Author Report Share Posted March 24, 2005 yaeh, i am at ft.bragg. thanks for the reply. i will try the choke test tomarrow if i can keep from fouling a plug. im thinking of trying an irridium plug tomarrow as well. expensive, but everyone swears by em though. right now i run ngk b8es. Quote Link to comment Share on other sites More sharing options...
dajogejr Posted March 24, 2005 Report Share Posted March 24, 2005 BR8ES are fine...I'd wait till you get the jetting down first. It'll foul a 8 or 10 dollar plug just as easy a 2 dollar plug... Quote Link to comment Share on other sites More sharing options...
kw04 Posted March 26, 2005 Report Share Posted March 26, 2005 hey where you at on bragg. what unit? Quote Link to comment Share on other sites More sharing options...
