sheefreak Posted March 21, 2005 Report Posted March 21, 2005 A buddy was riding his Warrior at dunes last year and quad all of a sudden quit. would not start. Replaced spark plug still no help. You can see spark, and it looks ok, so we tried to push start it. After a lot of pulling it around it will start and run, but if you let it die and sit for longer than 5 min, it won't start again. Thought it was compression, and compression test was terrible. So this winter we rebuilt top end, everything went well, timing is good but still won't start. Not even w/starter fluid. Did not try to push start, but assuming same results as before, could this be stator or some other electrical problem? Haven't performed meter readings on electrical yet, but wanted to get some input from you guys before chasing wrong problem. I know it's a four stroke, but thought some of you might be able to help. Sorry for the book. Quote
bansheefreestyler Posted March 21, 2005 Report Posted March 21, 2005 when the stator went on my shee you couldnt start it any way. i got pulled behind a truck trying to bombstart it and still wouldnt fire. and i think the stator provides the spark so if you have spark then i dont think its the stator Quote
sheefreak Posted March 21, 2005 Author Report Posted March 21, 2005 Spark Plug will even be wet, so I don't think it is a fuel problem. Used brand new gas and tried starting fluid. I just don't get it. Anyone elses input would be greatly appreciated. Quote
