njbanshee Posted March 21, 2005 Report Posted March 21, 2005 I have yfz 450 shocks mounted on +2 a-arms, but the front sitts a little higher than normal. How can i take the preload out? Is that the right thing to do? Quote
DIRTBIKEZ Posted March 21, 2005 Report Posted March 21, 2005 How does she ride? You are probably going to need that preload with the +2. You need to loosesn those two nuts by the top of the spring . Quote
NYCBanshee7 Posted March 21, 2005 Report Posted March 21, 2005 Loosen the top locking screw, then loosent he bottom one and you will be good. Use a spanner wrench to make life easier. I did it with a hammer and a flathead. When all the preload is out, it sits real nice. Love the way it rides, but havent taken it off many big jumps yet. Quote
racer Posted March 21, 2005 Report Posted March 21, 2005 I have yfz 450 shocks mounted on +2 a-arms, but the front sitts a little higher than normal. How can i take the preload out? Is that the right thing to do? 342424[/snapback] it very well could be the right thing to do. perhaps the only thing keeping the frontend from being higher is the binding of the front ball joints. im not for sure abou this, but i thought id throw it in there. Quote
