Capone Posted March 19, 2005 Report Posted March 19, 2005 Ok, my shee has ran good most of this winter, I tried this new gas, and messed with the air screw a bit cause it was warmer, well it started missing in the topend. So I jetted up, and got a different gas, and some new plugs(B8ES). Now it will idle for a bit, but when you rev is misses real bad, wont reach the powerband or nothing. Its terrible. I have 340 mains in it right now, and 30 pilots. I'm starting to think its something with the electrical, not positive. Its impossible to do a plug check although I did let it run for about 5 min, revving periodically, I pulled the plug and it was spotless, a dab of oil on each bridge of the plug. Also, its spitting hella oil out of the pipes. Any ideas please, please, please post! Quote
MILO Posted March 21, 2005 Report Posted March 21, 2005 Ok, my shee has ran good most of this winter, I tried this new gas, and messed with the air screw a bit cause it was warmer, well it started missing in the topend. So I jetted up, and got a different gas, and some new plugs(B8ES). Now it will idle for a bit, but when you rev is misses real bad, wont reach the powerband or nothing. Its terrible. I have 340 mains in it right now, and 30 pilots. I'm starting to think its something with the electrical, not positive. Its impossible to do a plug check although I did let it run for about 5 min, revving periodically, I pulled the plug and it was spotless, a dab of oil on each bridge of the plug. Also, its spitting hella oil out of the pipes. Any ideas please, please, please post! 341686[/snapback] unhook your e-brake, sometimes the problem is with that. what do you mean by 'this new gas' and 'a different gas'?? just the mix or what? if your stock, reset your air screws to 2 turns out and see if that helps. 340 mains seem pretty big, not knowing your mods though. list your mods and elevation. Quote
Capone Posted March 21, 2005 Author Report Posted March 21, 2005 '03 Shee 370cc K&N Pods Boyseen PowerReeds CoolHead - 18cc (110 octane) Wiseco ProLites FMF Fatty - PowerCore's I changed from c-12 to 110 leaded Clark gas. Ran shitty. Now I switched back, and also rejetted my carbs, and adjusted clutch. Since then its barely ran. There is a more active thread in the Repairs section of this site. Thanks guys. Quote
Capone Posted March 21, 2005 Author Report Posted March 21, 2005 http://www.bansheehq.com/forums/index.php?showtopic=42233 Quote
