Percy Posted March 19, 2005 Report Posted March 19, 2005 Hi, My mates Banshee seems to be flooding on one side. Left side gets hot and runs well at all speeds. Right side is cooler and floods at low end. Right card is overflowing fuel when bike is idling. Bike will not idle, unless choke is out. Any help will b gr8 and i will pass onto him Cheers, Percy Quote
rocketboy Posted March 19, 2005 Report Posted March 19, 2005 your float in your carb is causing it to flood out its either stuck or not set correctly ,get out your manual and check for pin holes in it and to see if its working and set properly Quote
Banshee~ Posted March 19, 2005 Report Posted March 19, 2005 your float in your carb is causing it to flood out its either stuck or not set correctly ,get out your manual and check for pin holes in it and to see if its working and set properly 341574[/snapback] yea that sounds right...try tapping on the float bowl with the end of a screwdriver Quote
