You want to synk the closed throttle slide height (idle) and then the throttle cable pull on the slides.
To sync the carbs look into the intake sides of the carb (not running and air filter off) and adjust the idle so that both carb slides are at the same height at idle postion (closed throttle). Then start it and adjust both carb idles evenly to get the desired idle.
Next (engine off, twist or press throttle) slowly take the slack out of the throttle cable and verify that both slides begin moving at the same time. If one comes up before the other then use the nuts on the carb tops (or knob on top of tors) to take the slack out of the cable on the side that the slide comes up late untill both slides begin to move at the same time. You can also check by holding the trottle open so the bottom of the slide is flush with the inside top of the carb and feeleing with your finger if both slides are even with the top of the carb.
