  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
Get an old timing plate and grind out the screw holes so it's retarded about 5 degrees and push start it backwards. It will run in reverse til you run out of gas :wacko: That's what I do when I want to back up :unsure:
WHAT SEEMS TO WORK FOR ME IT TO DO A MOTOR SWIVEL MOUNT GYRO X9000... REALLY SIMPLE.. IN A PUSH OF A BUTTONT HE MOTOR WILL TURN 180 DEGREES BUT WATCH OUT FOR THE PIPES SPECIALLY IF YOU HAVE DRAG PIPES THEY WILL BURN YOUR LEG. SOON AS THAT MOTOR IS COMPLETELY 180 YOUR READY TO RELEASE THE BUTTON AND OFF YA GO INTO REVERSE... ... ONLY PROBLEM I HAVE FOUND SO FAR IS IN THE X9000 MODEL THE BUTTON GETS STUCK AND THE MOTOR WILL KEEP DOIN 360'S IN YOUR FRAME AND THAT CAUSES YOU TO SPIN CIRCLES RAPIDLY. I'VE GOTTEN DIZZZZZY AND WELLLL 078.gif
336286[/snapback]
yeah i upgraded o the gyro x1100 no problems yet. banghead
