AUSSIE BANSHEE Posted February 25, 2005 Report Posted February 25, 2005 HAVING TROUBLE REMOVING MAIN BOLT FROM SWINGARM BOLT IS LOOSE AND SPINNING BUT CANT GET IT TO BUDGE ANY IDEAS? Quote
KoooPSD Posted February 25, 2005 Report Posted February 25, 2005 Hammer and a screwdriver...........hit that bitch out like it owes you money... Quote
AUSSIE BANSHEE Posted February 25, 2005 Author Report Posted February 25, 2005 Hammer and a screwdriver...........hit that bitch out like it owes you money... 329397[/snapback] THINK I MIGHT HAVE TO TRY A SLEDGE HAMMER , THIS BITCH IS TIGHT! Quote
MILO Posted February 25, 2005 Report Posted February 25, 2005 how do you have your quad supported? maybe it's in a bind and you need to lift/lower it a little. i had to mess with mine like that a few times till i got it all the way out. if you think that's bad, wait till you pull the stock rear axle out for the 1st time. that really sucked!! Quote
boonman Posted February 25, 2005 Report Posted February 25, 2005 Make sure the fuel is off, and tip the bike on it's side. Wail on that thing with a BFH. It will come out. If it doesn't, you will have to cut it out, which requires a steady hand.... Quote
Blacksmith Posted February 25, 2005 Report Posted February 25, 2005 Like stated before, put the bike on its side. Soak the bolt in PB Blaster overnight and then go after it with a brass drift and a large hammer. Keep in mind that the bolt is in contact with a sleeve all the way through the swing arm. A little corosion in those tight quarters will cause you to need to use a lot of lube and a lot of force. Use a good drift so as not to mushroom out the threads, or you will just make you problem worse when it does start to come out. Good Luck Quote
