My sprocket hub has some slop on the axle. I've been hearing my chain skipping and upon replacing the chain it hasn't been so bad but I still heard it from time to time. Could it be the splines in the sprocket hub instead? If so which are probably striped? The hub or axle... or both?
309643[/snapback]
If it strips the sprocket hub, I believe you won't be going anywhere!
The hub shoulb be softer than the axle, so it will strip first.
