ok I changed the plugs no affect...
I checked the restance for the stator it checked out fine....  I checked the resetance on the coil primary lead it was fine... When I checked the plug leads I can't get a ohm reading on either side,  I even removed the caps and still no movement on my ohm meter,  Did my coil go bad?  The 'shee fires and idles fine.  If the coil was bad would it run?
312752[/snapback]
Did you adjust the timing plate correctly?
