i bought the alba swingarm and i have my upp rear chain slider off my stock arm and usally it bolts up between the chainslider mount and the swingarm on the alba arm it doesn't fit between the mount & arm and even if it did it is not aligned with the sprocket and there is nothing to screw the bolts into. If u put the slider on the outside of the mount it does line up but what will i have to do to bolt it up cause the stock bolts do not even fit threw the mount holes, i guess get bolts that do and put a washer and nut on the back idk any help would be great. Or if anyone has a swingarm and has had this problem help!!!!!
Which one do you have... round housing or the stock bearing carrier? Take a picture of your problem if you can.
