Do the stock airbox tabs interfere with K&N pod filters? I'm gonna cut the stock pipe "bumper" tabs, the lower front fender arm mounts and whatever else off that I don't need before I go to the powdercoater. Anything else I might want to look at?
I cut mine off! the pods are able to sit in there perfect now. As for other stuff, cut the stuff you realy dont need. You can use zip ties to hold stuff in place like cables etc.. This will also give you some weight reduction. :D
