What is the inner diameter of the radiator hose on the shee? Also need to know the size of the tie rod slotted hex nut/castle nut, the nut that holds it on the spindle arm, thread pitch and diameter? Is there a difference on the size and pitch of the rod threads that go inside the tie rod itself compared to the spindle arm? Thanks in advance fella's.
aprox 3/4 on the hose,the size+thread pitch on both of those are 10mm+1.25,i did'nt check the tie rods,just the ends+the spindle nuts.
