ok here is what i need:
-steering stem bearing with seals
-all 4 front wheel bearings and seals
-swing arn needle bearings, with seals, washers, collar (everything needed)
who makes good bearings? Are the no name brands on ebay ok?
what type of grease should i use with all these?
how much will i plan to spend on all this?
while i am at it, should i replace the carrier and a-arm bearings also?
I know this is alot of questions....thanks for your help guys...this is my first comlplete tear down and want to do it right.
I have used Pivot Works on all my LT's & haven't had any problems with them. Their kits usually contain all the sleeves & seals needed.
For grease I use Bel Ray waterproof grease.
Rocky Mountain seems to have good prices on the kits. 27 for the front & 42 for the swinger.
