Is this a bad idea? I heard that the high heat from baking the powder is bad for the Jugs? What does it do to them? Thanks......
297980[/snapback]
You might want to read this. It has some really good info:
http://my.execpc.com/~davewrit/Powder.html
Here is an excerpt from it:
The question keeps coming up about doing cylinders and cylinder heads. I have seen it done, but I would never do it to one of my own. I would STRONGLY advise NOT to coat these. You want to dissipate heat, not retain heat by putting an insulator over it! . Powder coating can be a great thermal and electrical insulator. If you must have it coated, use a thin film of wet paint.
