H250RHATER Posted December 25, 2004 Report Posted December 25, 2004 I have a 40 overbore 350 w/coolhead and 21cc domes,I would like to run a 19cc dome. At when cc domes does a crank have to welded. Quote
Redlined Posted December 25, 2004 Report Posted December 25, 2004 I have a 40 overbore 350 w/coolhead and 21cc domes,I would like to run a 19cc dome. At when cc domes does a crank have to welded. 297782[/snapback] Think of it as insurance. You may get lucky and ride for a long time without doing it, or you may do a few mods and find yourself screwed one day. It sounds like you are going to start down the trail that most Banshee owner head down, more power, so I would recommend doing it now. Quote
SICK BOY Posted December 25, 2004 Report Posted December 25, 2004 If you have the cases split,I'd do it no matter what mods you have. Quote
H250RHATER Posted December 26, 2004 Author Report Posted December 26, 2004 hot rod crank cool head 21cc domes thinking of going to 19cc and in a few days im getting a mid range port job done by Paul Turner along w/ cpi exahust i have 28mm flat slides boost bottle 1/2 " REED SPACERS v-force reeds wisco pistons Quote
BdBanshee Posted December 26, 2004 Report Posted December 26, 2004 If you have the cases split,I'd do it no matter what mods you have. 297820[/snapback] I'm with SICK BOY, when you have it apart get it done. If you aren't ported I wouldn't worry about it too much. Some are put together better than others and last a long time even with lots of mods, and some start separating with just pipes. The average crank works fine with pipes and head work. Quote
