streetshee Posted December 21, 2004 Report Posted December 21, 2004 does anyone know in which groove the oil ring goes with the pro x pistons? upper or lower???? ive forgot! or maybe i never knew!!? Quote
streetshee Posted December 21, 2004 Author Report Posted December 21, 2004 does anyone know in which groove the oil ring goes with the pro x pistons? upper or lower???? ive forgot! or maybe i never knew!!? 296171[/snapback] its like an 8 sided pentagonal shaped ring that i think is normally on a 4 stroke piston,cant understand why its included in the pro x set for banshee???????? Quote
ledofthezep Posted December 21, 2004 Report Posted December 21, 2004 You may hit Meat up or check his site & see if you can find what you're looking for in any pics there...no experience with pro-x's myself. http://www.thebansheezone.com/Bansheezone/Engine.htm Here's another site with info on top-end rebuilds & it talks about the Pro-X pistons in one section, but unfortunately doesn't say jack that relates to oil grooves? "... from Eric Gorr's book "Motocross and Off-Road Performance Handbook". http://www.eric-gorr.com/twostktech/twotop...ml#The%20Piston Quote
