HEY WHATS UP GUYS NEED SOME HELP AGAIN WITH THE SHEE
EVERYTIME I RUN MY SHEE ITS CUTTING OUT ON THE RIGHT SIDE UNLESS YOUR HAMMERING IT THE EXHAUST ISNT EVEN HOT LIKE THE OTHER SIDE AND IT PHASES IN AND OUT IV CHANGED PLUGS IT MADE NO DIFFERNCE AT ALL MY COMPRESSION IS THE SAME SO I RULED OUT HEAD PROBLEMS I FIGURED IT WAS A CARB ISSUE WELL THE OTHER DAY ME AND A BUDDY WENT RIDIN AND WERE REALLY ROCKIN IT AND BY ABOUT THREE HOURS OF HARDCORE RIDIN SHE WAS BLOWIN GLOWING ASH OUT THE RIGHT PIPE I FIGURED IT WAS LOADIN UP MAYBE SO I DROVE HER HOME LET HER COOL STARTED IT THE NEXT MORNING SHE FIRED RIGHT UP NO PROBLEM EXEPT SHE STILL CUTTIN OUT ON THAT RIGHT SIDE THE PROBLEM HAS COMPLEATLY MADE ME LOOSE MY LOW END IT ONLY ACTS HALF WAY DECENT WHEN IM FLOORING IT I AM BAFFLED AND AM SUPPOSED TO RIDE TOMMAROW CAN U GUYS HELP ME AND TELL ME WHATS GOING ON THNX AS ALWAYS U GUYS ROCK
Sounds like a jetting issue or a airleak in some way...What do Ur plugs loolk like ? brown or black?
maybe u have clogged jet on that side.. carbs out of sync.
my plugs are actully pretty clean there brown it has been backfiring a lot where do u think a leak would be at?
288981[/snapback]
Spray some carb cleaner on different area and if it idles up U have a air leak..
More than likely it's around the carb boot"has a crack" or the intake is loose..
