Well today i was jus cruzin down the road in 6th gear at like 1/4 throotle when all of a sudden the rear tires just locked up. I thought it was my rear brakes but it wasnt. I can start the bike and it will run but when you let out the cluch it stals and acts like the rear brakes are locked. I can only mannage to shift it down to 4th but no lower and can ride in 4th but soon as i try to shif to 5th the rear wheels lock. Whats wrong wiht it? Any help would be nice :cry:
have you had it apart before? on my warrior the case broke inside, the pin that holds the starter gear snapped and broke the hole in the case and the cover. right now i have the case split and am going to install the new case half today, it looks pretty stright forward inside so you might want to pull it apart and see if something snapped. but on the upside you can put some new goodys in there while you have it apart.
288772[/snapback]
No i havent had it apart yet. It just happened yesterday(friday) but yea ima have to take it apart and see
