tats4life Posted December 1, 2004 Report Posted December 1, 2004 I got a major fuckin problem.....my pro design intake does not work with my v force 2 reeds....what intakes are you guys using. And I have 28 pwk's. One of the two is going in the fuckin trash can before this shit is over with.... Quote
sredish Posted December 1, 2004 Report Posted December 1, 2004 My manifold does, but.... you already knew that. Seriously, hope you get it figured out yo! Quote
tats4life Posted December 1, 2004 Author Report Posted December 1, 2004 thanks jackass.....called pro design.......i'm just gonna take a cut off wheel to it....the only difference in the intake is the two draft tunnels on the backside...they make an intake to fit v force reeds...the intake doesn't have the to intake draft tunnels on the back side........problem hopefully solved...if not gonna trash an intake and buy a new one. Quote
sredish Posted December 1, 2004 Report Posted December 1, 2004 thanks jackass.....called pro design.......i'm just gonna take a cut off wheel to it....the only difference in the intake is the two draft tunnels on the backside...they make an intake to fit v force reeds...the intake doesn't have the to intake draft tunnels on the back side........problem hopefully solved...if not gonna trash an intake and buy a new one. 287115[/snapback] maybe someone can swap with you, but I doubt you wanna wait long enough to find out. chop away and let us know. Quote
Banchetta Posted December 1, 2004 Report Posted December 1, 2004 I have the pro design intakes. I just put the intake on the edge of a bench and tapped the guide or "diverter" out...They are only pressed in, but you need a hammer or press to get them out. Quote
tats4life Posted December 1, 2004 Author Report Posted December 1, 2004 the piece u tapped out i took out long time ago...i gotta remove the parts that hold the diverter Quote
Banchetta Posted December 1, 2004 Report Posted December 1, 2004 Mine must be different, my diverter was only pressed into a tight slot in the cage. The reed cage dropped right into the intake after... Quote
Meat Posted December 1, 2004 Report Posted December 1, 2004 break out the die grinder tats and staaaaaaart grindin'. Quote
tats4life Posted December 1, 2004 Author Report Posted December 1, 2004 break out the die grinder tats and staaaaaaart grindin'. 287232[/snapback] that's the plan today at the shop....if i trash'em then i'm just gonna have to order the right intake cause that mod quad or boss intake is to damn tall to run an airbox with. Quote
Flyin_Shee Posted December 3, 2004 Report Posted December 3, 2004 If you're going to throw away an intake...I'll take it . Quote
