The following copied from BenBB's Electrical FAQ, thanks Ben
Click on this sentence for the complete BenBB's Electrical FAQ
Q#29:How do I test the Ignition Coil on the Stator?
A#29:Using an ohmmeter and the specifications above, check the resistance between the red wire and the green wire on the four-wire harness coming out of the stator. Find the four-wire connector (usually white), at the front of the airbox on the right-hand side of the bike. Depress the little plastic retainer on the connector and disconnect the two connector halves. Take a look at the wire on the connector towards the front of the bike, it should run under the carbs and into the left-hand side of the motor
Edited by J.J.
