370banshee Posted November 20, 2004 Report Posted November 20, 2004 what shoudl a stator ohm out at?? and what wires do you test across with teh ohm meter??? i think my 87 shee trashed a stator. Quote
J.J. Posted November 20, 2004 Report Posted November 20, 2004 (edited) The following copied from BenBB's Electrical FAQ, thanks Ben Click on this sentence for the complete BenBB's Electrical FAQ Q#29:How do I test the Ignition Coil on the Stator? A#29:Using an ohmmeter and the specifications above, check the resistance between the red wire and the green wire on the four-wire harness coming out of the stator. Find the four-wire connector (usually white), at the front of the airbox on the right-hand side of the bike. Depress the little plastic retainer on the connector and disconnect the two connector halves. Take a look at the wire on the connector towards the front of the bike, it should run under the carbs and into the left-hand side of the motor Edited November 20, 2004 by J.J. Quote
370banshee Posted November 20, 2004 Author Report Posted November 20, 2004 thanks i found tha in the manual eariler but i didnl;t knwo there was such a website about that. whats the link??? Quote
370banshee Posted November 20, 2004 Author Report Posted November 20, 2004 oh i just realized that you put the link in your post. this new formeton teh site makes links invisible. maybe somebody should mention that to lee Quote
fixitrod Posted November 22, 2004 Report Posted November 22, 2004 I had a stator that tested good and was bad just to though in a monkey wrench. Quote
