Rescuejeff Posted November 18, 2004 Report Posted November 18, 2004 I borrowed a friends CDI to test mine out and pushed his pins throught to hard wire my plug on since he has a newer shee then me. He has a 3GG-10 with a four and five wire plugs. I need to know th e configuration of the five wire plug. I know where green and orange and black/white goes but where does the red go, next to orange or black /white??? Thanks in advance. Quote
RNBRAD Posted November 18, 2004 Report Posted November 18, 2004 Need more info, not sure I'm understading this. You have a pre 96 banshee with the 4 plug and your buddy has the newer shee with the 5 plug? Tell me what you need maybe just rephrase it. Quote
Rescuejeff Posted November 18, 2004 Author Report Posted November 18, 2004 I took his five wired plug off his CDI and pushed the pins through so I could wrap my plugs wire around his to run it to test that my cdi was bad. His has the four wire(white/red, whitegreen, red and green) then another plug with (black, Black/white, orange, red with a strip and green). I figured out the green(since I never took it loose, but found the location of the orange and black/white wires through a picture, but it did not show me the red or black wire. So can you tell me which goes between the orange and green wire?? Thanks again Quote
RNBRAD Posted November 18, 2004 Report Posted November 18, 2004 The only difference I could find between the difference in years of the cdi is the newer one has a 5 prong plug with a green/yellow wire and the older one doesn't. This is for the parking switch. Quote
RNBRAD Posted November 18, 2004 Report Posted November 18, 2004 Otherwise all colors of wires on both shee's all match up accept for that one wire. Each CDI unit should have all the same wires accept the one green/yellow. Older unit has two 4 prong plugs, the newer one has a 4 prong plug and a 5 prong plug. The reason for the 5th prongs is the green/yellow wire as stated above. All colors are the same otherwise. Quote
Rescuejeff Posted November 18, 2004 Author Report Posted November 18, 2004 Thanks your the bomb. Have a great day. Quote
