hi all and can some one help me out on this . which porting has more acceleration and good top end ? and for the powerband which one come's faster ? my riding style is draging some friends cruising on the street and sands and my setup is 35mm single carb FMF SST pipe timing plate and stock gearing .
That is totally dependent on the porter and their style of MX versus trail port. Definitely find a ported who you feel will do you the best job and address this question with them. Your question will be best answered this way.
There is no exact definition of what is a trai port or an MX port, but I think trail porting is typically a light "clean up port" or some builders call it stage 1 porting. It is usually fairly cheap, like $100 to $200.
MX porting is usually more complicated, may involve adding boost ports, and opens up the ports a lot more for more flow and yields more overall power. Basically tries to get as much flow as possible without loosing bottom end. Costs around $400.
Kinda ambiguous answer, but I hope it helps.
