Percy Posted November 14, 2004 Report Posted November 14, 2004 Hi Guys, Today I did a stupid thing. Washed the shee and when I do this, I take off the filter and block the airbox with a big cloth. Later in the day I decided to go for a spin round the block as I fitted the long range tank today. I tried to start it, (with the airbox still blocked) for about 30 mins. I kicked and kicked as well as tried to run start it down a hill. Once i relaised my error, I cleaned the plugs up, put the clean filter back in and after a few (20) kicks it fired up. I have run it up the road and seems 100%. Will this have done any damage? I shold not think so, as it did not fire up, so was not actually running without air? Appreciate any help/advice Cheers, bruce Quote
stclark04 Posted November 14, 2004 Report Posted November 14, 2004 Youll be ok. As long as you didnt get any water in it, ur fine. Quote
Percy Posted November 14, 2004 Author Report Posted November 14, 2004 Youll be ok. As long as you didnt get any water in it, ur fine. 280739[/snapback] Definately no water got in. It was quite hard to start though, even when I put the filter back on. Normally starts with 2 kicks. Was that just cause it was all gunged up and flooded from me trying to start it with no air...? Quote
