fixitrod Posted October 20, 2004 Report Posted October 20, 2004 The coils I've seen for spark plugs are a black sleeve with a taper on the top to keep them from turning in. Those coils will work though. Here are some instructions I looked up for you...... http://www.toolsnextday.ltd.uk/Helicoil_Ki...icoil_usage.htm Quote
QuadMX Posted October 20, 2004 Author Report Posted October 20, 2004 The coils I've seen for spark plugs are a black sleeve with a taper on the top to keep them from turning in. Those coils will work though. Here are some instructions I looked up for you...... http://www.toolsnextday.ltd.uk/Helicoil_Ki...icoil_usage.htm Thanks a lot rod! Quote
fixitrod Posted October 21, 2004 Report Posted October 21, 2004 The coils I've seen for spark plugs are a black sleeve with a taper on the top to keep them from turning in. Those coils will work though. Here are some instructions I looked up for you...... http://www.toolsnextday.ltd.uk/Helicoil_Ki...icoil_usage.htm Thanks a lot rod! No problem. Hope it helps. Quote
