they should scream on the topend, that is if you have the motor to pull them. your bottom will not be as strong, dont know how this will effect you accerleration. how much porting do you have?
Edited by therail
Very mild port, its mainly someone that had it before me tryed to play around with the ports and open em up a little, but got some brand new pistons in it noss head reed spacers pipes the whole nine yards thats gotta demand more fuel.. no??
not that much fuel. its dyno proven that stock carbs do give the best results until you get some pretty wild porting. PM Banchetta. he is the god of the dyno and he can direct you to more technical info about carbs on a mild motor.
