its a yfz450 yes, but i need some help that i dont normaly get on the central. Heres the deal. Ive just put in the new lighter flywheel and now it dosent start. However when i touch a metal bar across the battery's terminals the starter turns the motor. The starter motor turns but there dosent seem to be a spark. What could the problem be?
Also ive no chain on the bike as i just put on a new axle and even when the bikes in neutral the sproket still turns, this normal?
Anythings welcomed
Can't help ya with the starter problem...ive always used kick/pull starters. But yes, it is normal for the sprocket to turn in neutral...It has no resistance. You could stop it with a finger (but i dont recommend trying it).
