ok i need some help from someone that knows what they are doing. I just put my banshee back together and have to hoses that go nowhere. I think they are ok but i just dont want to f*ck up my engine. ok so i have both the big hoses in the right spot. Then i have one that goes from the top of the rad to the bottom of the coolant tank. one more comes out of the rad and into the head of the engine. so does the hose for the top of the coolant tank just go to the ground? Also there is a t shape of black tubes near the carbs and there is one that goes nowhere.(its not the carbs overflow i know that much) Should it go somewhere? Also thanks for the help. Also if someone has pictures or could take a picture of the hoses all put on that would be great. :cheers:
The one from the coolant ressy, is an overflow tube. The "Y" one your talking about is a vent of some kind. but yeah, sounds like everything is in the right place.. :headbang:
