Dlnoss,
I am finally ready (I believe) to swap to the noss head from my cool head. I'm sick in tired of this thing leaking and it has been nothing but trouble. I know my deck height is perfect so it has to be something with the head. I also had a problem with the small amount of material on the underside of the head. It began to crack and will probably break in the future.
Could you provide a photo of the underside of the head. I would like to get a close up shot showing the O-Ring gooves. A close up shot showing both the O-ring grooves on the underside of the head would be appreciated...
Thanks a ton....
(please PM me for a price and where to order at...)
Here's a picture of the bottom
I'm not sure I understand what is cracking on the PD head. You will need to re-install the stock studs if you change to the Noss head.
-David
