what are those really cool needle bearings everyone is gettin these days? im thinkin ill get some for my next rebuild.
thanx cole
thanx cole
TZ bearings..... Stock is a 7 ball bearing and the TZ is 10
well fixitrod, i think you may remember the convo we had a while back about me needing to rebuild my crank so ive decided too. the catch, if you can even call it that, is that i now work at a local dealership so i can get it done cheap. like a case of beer cheap. so can you hook me up with some part numbers for those bearings? i think i just want the two outside ones to be TZ, while keeping factory wiseco inners. also i will be looking at tucker rocky to see what they can get me a 4mm for. :headbang:
I remember. You can read the number on that pic. I'm not sure what the other side number would be. That is the pto side (clutch side). It the side that take a lot of beating and goes out the most. That's what my builder said anyway. Looks like that part number is 70241-1.
