banshee35twin Posted September 3, 2004 Report Posted September 3, 2004 03 shee with t4s and clampons running 290 mains. pulls hard 1st to 5th but it won't pull 6th. plugs look closer to black than tan. thinking about droping to a 280.what do all of you think? Quote
lincster Posted September 3, 2004 Report Posted September 3, 2004 What elevation? Sounds like you are lean to me with clamp ons unless you are like 4000' elevation. Was your plug color tested on a WOT test? Quote
sredish Posted September 3, 2004 Report Posted September 3, 2004 does it just fall flat, or bog and sputter. I'm with lincster, I'd go up to 300 or even 310 with your tampons and see what shee does. elevation? gearing? Quote
kenr74 Posted September 3, 2004 Report Posted September 3, 2004 I'm running Fattys and clampons at sea level. I have 350's in right now and am just a little rich. Quote
banshee35twin Posted September 3, 2004 Author Report Posted September 3, 2004 elavation is 1000 ft and about 80 degrees. it does not sputter it just bogges . and it has stock gearing in sand with sand stars. plug test was not at wot just after i got back to camp. Quote
sredish Posted September 3, 2004 Report Posted September 3, 2004 elavation is 1000 ft and about 80 degrees. it does not sputter it just bogges . and it has stock gearing in sand with sand stars. plug test was not at wot just after i got back to camp. your lean bro. start going up with the mains and start with a 310. Quote
lincster Posted September 4, 2004 Report Posted September 4, 2004 elavation is 1000 ft and about 80 degrees. it does not sputter it just bogges . and it has stock gearing in sand with sand stars. plug test was not at wot just after i got back to camp. your lean bro. start going up with the mains and start with a 310. Yep, I agree with sredish. If you checked your plugs after cruising back to camp, that was not the right place to check them. Start increasing the main size. kenr74, glad to see someone else who jets big. I run a 2:1 Toomey and am running 370 mains at Glamis. Quote
