Ok the 87 shee has the steel like caps sleves if i get bearings do i still need to buy new sleaves if i got bearings?
or how does that work?
Yeah the sleeves are tore up. So in the A-arms and J-arms i put the bearing in first then, the sleeves. But even though i got bearings i still have to use the sleeves right?
Did you read the instructions with the full color step by step photos I sent you? Take the old plastic bushings and throw them away. Put the bearings in the Arms {as shown} and put the sleeve in the bearings, put the dust caps on, put the Arms in the frame, put the bolt in the Arm, put the nut on the end, do the same on the others.
