Piston Help Identification...?
harley_sr
thjose are 64.50 mm pistons. at least thats what the cylinders should read. the pistons them selves will actually be a little smaller. depending on how bad the cylinders are you can just go over to maybe 64.55. or 64.60. different companies make different sized pistons. but there .5 mm over stock.
ok my piston has a little play in it, I am going to order a new top end kit tomorrow, what should I look into getting? 6 over? What is some ggod brands to go with?
The Wiseco pro-lite is hard to beat for reliability. Its also common for cylinders not to clean up on .010" over bores. you will need Wiseco part # 513MO6475 if it WILL clean up at an additional .010" overbore. You will need part # 513MO6500 if it wont(.020") over where you bore is currently...Jim
